Need a no-frills, cool and quiet case
survdirt
5
Purchase date now
Budget $1000
Usage Autocad,3d survey simulators,Office programs,Internet email,Gaming
Parts not required Monitor,Keyboard
OC-maybe Cf-no
Parts just ordered
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 ... - Retail
ASUS P7P55D Deluxe LGA 1156 Intel P55 ATX Intel Motherboard - Retail
Intel Core i7-860 Lynnfield 2.8GHz LGA 1156 95W Quad-Core Processor Model BX80605I7860 - Retail
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7D-4GBRM - Retail
SAPPHIRE 100283L Radeon HD 5770 (Juniper XT) 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card - Retail
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
I need a case without all the bling. I want something with good cooling, quiet, and not real big.
I am considering Antec 300 or CM Gladiator 600. Both are around 56.00 at diff. stores. Any opinions.
Also need HD, DVD burner,Card reader
I like lian li k56 and k58 no window. CM 590 also in. So out of the five which has best cooling, quietest, small size, best dust filtering, ease of installing components, and price. I am not looking for the cheapest but dont want to go too crazy because I went a little over on major components. I want a bottom mount psu.
I bought a Lian-Li PC-7F for my build last month (intending to re-use it for more builds in the future) and have been very happy with it so far. It's light-weight, quiet, and unassuming - just cut the wires for the LED's on the front fan, or replace it with the 140mm fan of your choice. It also has bottom-mount PSU.
It's a bit pricey, but i'm planning on reusing it multiple times, so i didn't mind paying more for a component that i can use for upwards of 7 years (like my PSU w/ 7-year warranty)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112194&cm_re=pc-7f-_-11-112-194-_-Product
