Need a pc build for 1080p & 60fps
lazer-man16
Commendable
Jun 24, 2016
8
I'm hoping for at least mid to high settings on most games at 1080p 60fps. Some of the games I will get are WoW, skyrim, fallout 4, gta v. My budget is $1500(i might be able to go a bit over if it's completely necessary).
I'll also add that I don't plan on overclocking.
Here you go, coming under your budget. This is an i7 option if you'd like to max out like all games and future proof your PC.
You don't have to overclock but you always have the option to with this build.
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor ($345.88 @ OutletPC)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler ($43.53 @ Amazon)
Motherboard: Asus Z170-E ATX LGA1151 Motherboard ($107.98 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory ($64.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($89.99 @ NCIX US)
Storage:...
You should have no problem with your budget.
Your games will benefit from fast single thread core speeds.
Regardless, give yourself the option of overclocking.
A I5-6600K will do the job. But, pair it with a Z170 motherboard. You can easily get a 30% overclock.
You need not overclock, but when you realize how simple the process is, you might change your mind.
A GTX970 class card will play most games very well at 1080P.
Rumor is that the RX480 will be in that category and be attractively priced. It might be good to see what is really announced.
Nothing wrong with stronger if you might go to 1440P.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($197.99 @ SuperBiiz)
Motherboard: ASRock B150M Pro4 Micro ATX LGA1151 Motherboard ($74.99 @ Newegg)
Memory: *Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory ($31.99 @ Newegg)
Storage: *Seagate 1TB 3.5" 7200RPM Hybrid Internal Hard Drive ($69.88 @ OutletPC)
Case: Corsair SPEC-01 RED ATX Mid Tower Case ($37.99 @ Micro Center)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($87.98 @ Newegg)
Optical Drive: Lite-On iHAS124-14 DVD/CD Writer ($14.89 @ OutletPC)
Other: Sapphire Radeon R9 390X 8GB Nitro Video Card ($309.99)
Total: $825.70
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2016-06-25 08:08 EDT-0400
You can also take a look at these cards:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487164&cm_re=EVGA_GeForce_GTX_960-_-14-487-164-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16814202166
http://www.newegg.com/Product/Product.aspx?item=N82E16814487088
Just a small note regarding buying a gpu for the time being, Nvidia is making a huge price cuts over the 900 series, I saw the MSI gtx 980ti golden edition sample for 400 USD and after rebate it could reach 370 USD ! and if you are not believing me then take a look at this article http://www.pcgamer.com/pascal-pushes-down-pricing-on-geforce-gtx-980-ti-980-and-970-graphics-cards/, and if you have checked the links above you will notice the big price cuts on the gtx 970 and 960.
And I think AMD will follow the same lead after they release the 400 series, so my advice is to wait for AMD until they launch their new cards, maybe you will prefer the newer generation or maybe you will find a better deal on older generation.
But if buying a PC is an absolute necessity then you can go for it and buy a build such as the one I suggested for you, either way you won't regret it at all. Good luck and happy gaming mate :)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($47.49 @ OutletPC)
Video Card: MSI GeForce GTX 1070 8GB Video Card ($429.99 @ SuperBiiz)
Case: Corsair SPEC-01 RED ATX Mid Tower Case ($39.99 @ Amazon)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($89.99 @ Amazon)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($85.95 @ Amazon)
Total: $1360.67
Generated by PCPartPicker 2016-07-08 11:52 EDT-0400
