I'm willing to spend around 7000-8000€ for the PC alone. I live in Austria, Europe and I don't think I'm near a Microcenter. I have already decided on multiple parts, but it is my first time so I am unsure if it works well together. I am looking for a Gaming build that can handle 4k/240hz in demanding games and is as quiet as possible. I am not going to do overclocking for now. I am planning to undervolt the GPU for quieter performance. Unsure if I have to undervolt the CPU too then...
Already picked parts:
Other setup parts already picked:
One more question: Are CaseKing and Amazon safe to order from trustable? Or do I have to buy every component from the offical websites?
Please correct me if any of the components don't work together or if there are better options for this system and I'm open for any tips with installation, picking parts, etc... and please tell me cable management comes with an instruction for every component because I have no idea where to plug in what... :c
- CPU: Ryzen 9800X3D
- GPU: MSI GeForce RTX 5090 32G SUPRIM SOC
- Motherboard: ASUS ROG Crosshair X870E Hero
- SSD: Samsung SSD 9100 PRO 4TB, PCIe 5.0 (as main ssd with the Operation System of Windows 11 Home)
- SSD2: Samsung SSD 990 PCIe 4.0 4TB (for games)
- PSU: Seasonic PRIME TX-1600 1600W Noctua Edition
- RAM: G.SKill Trident Z5 Neo 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory
- Mouse (I'll use my current one)
- AULA F75 Keyboard (using it wired)
- SteelSeries Arctis Nova Pro Heaphones (wired version)
- Monitor (4k/240hz and an OLED screen. It doesn't really matter if it's curved or not)
- CPU cooler: Any quiet liquid cooler (I want a liquid cooler that I can run at silent mode even during heavy gaming. And one where I can maybe change the fans to Noctua fans. Looking at the Arctic Liquid Freezer ||| Pro but it is way too thick for the ASUS case and 3mm too thick for the Antec case too...would it still work with the Antec one though?)
- Case: ASUS ProArt PA602 Wood Edition Tempered Glass (It doesn't work with the PSU's dimensions (190mm vs 210mm) so could I just remove the hard drives and it would fit?)
- Case2: Antec Flux SE (No idea if this works with the PSU's dimensions...According to the website I think it does "Max PSU Length: (Include Cable) ≤ 235mm with HDD)"...also it doesn't support 200mm fans so thats a bit of a minus but the sound-damping side pannels are good)
- ASUS CASE - Fans(changing the built-in ones): NF-A20 PWM 200x200x30mm (x2 as intake), NF-A14x25 G2 140x140x25 (x2 as exhaust)....do they fit into the case? The built-in 200mm fans are 200x200x38....
- ANTEC CASE- Fans(changing the built in ones): NF-A14x15 G2 140x140x25 (x3 intake on front, x2 intake on bottom, x1 exhaust on bottom)...this will balance with a 360mm AIO mounted on the top I think...
- Extra: Thermal Grizzly Contact Sealing Frame AM5 (Is it easy to install and does it improve/decrease performance in any way?)
