Need a quick help about PSU!
salerhino
1,263
Is this PSU any good and is this:https://www.kupujemprodajem.com/Napajanje-450W-Be-Quiet-NOVO-uvoz-DE-48859522-oglas.htm?filter_id=30265303
Same as this:
http://www.bequiet.com/en/powersupply/676
I find it hard to believe that it has 2 x 6+2 pin.
Also I can't see from seller's picture if that is the exact same PSU so help would be MUCH appreciated!
Price is 12 euros and the PSU is new.
Definitely just try to invest into a legit power supply from a legit retailer. use the PSU Tier List that I linked you to help you find a good one. Use pcpartpicker website to help you narrow down your results. I would not recommend anything less than 80+ Bronze rated.
That is what I was thinking aswell, if someone can confirm or deny that I would be grateful!
I think it is not knockoff because seller is not really into PCs so he is selling it cheap.
honestly, i think it would be a good idea for you invest a little more than just $12 euros...if it shorts, it might take out the rest of your pc...
and get a brand new one if i was you, not only will you get better quality and reliability, but you also have peace of mind with warranties too. buying it used is a gamble at best.
