Need a quiet, cheap cpu cooler for my e8400
kel varnsen
27
any suggestions? any of the following any good:
THERMALTAKE Mini Typhoon
ZALMAN CNPS8700 LED CPU Cooler
ZALMAN CNPS8000 Ultra Quiet Low Profile CPU Cooler
ZALMAN CNPS9500LED Ultra Quiet
THERMALTAKE Golden Orb II
THERMALTAKE Ruby Orb
THERMALTAKE Big Typhoon VX(would this fit into my p182 cabinet?)
or should i just go for a cooler master hyper 212?
the most important thing is cost and noise. it doesn't have to be the best cooler, as i won't be overclocking, but i need it to be quiet and cheap. any good suggestions?
omicron_15
56
I am using a Xigmatek 1283, its very quiet with the included fan and has excelent cooling, I picked mine up for 40, not sure if that is out of your budget, it is also a large cooler, make sure you have the space.
I should add that's it's worthwhile to actually listen to the HSFs that's a feature at Frostytech. Some of them may be lower in decibels, but they have a high pitched keening sound that can really be irritating (at least for me)
KyleSTL
1,678
Ok, the TRU/TRUE are not "cheap" as the OP suggested. Please read what is being requested.
Good choices:
Cooler Master Hyper TX2
Xigmatek S963 (extremely cheap and high performance, best bang/buck)
Xigmatek S1283 (cheap and top-end performance)
Scythe Ninja (very quiet, even at full speed)
Scythe Mini Ninja ( " )
Scythe Mugen/Infinity ( " )
kel varnsen
27
as i said, there are some issues regarding what's available and what's not. xigmatek isn't. i'm ordering the cpu cooler from the same place i'm ordering the rest of my pc components. that limits the field slightly. besides, i can just set the typhoon to 6-700 rpm and it'll be silent as f***, no?
KyleSTL
1,678
based on those HSs that are available I would go for the Akasa AK-965
http://www.amentio.no/PartDetail.aspx?q=p:1632400;gr:0
It performs almost identically to the S963 ( http://www.frostytech.com/articleview.cfm?articleid=2137&page=4 ) and is much cheaper than the Typhoon (which is quite dated).
I would say the Thermaltake comes in second (without knowing the currency conversion), although the AK-965 probably outperforms it for less $$$. Avoid Zalman like the plague, they're overpriced and outdated.
Edit: here's the current FT chart, and the Akasa seems to be holding its own, even against newer designs.
http://www.frostytech.com/articleview.cfm?articleid=2281&page=5
rgsaunders
401
The CNPS9500 works well and is quiet, I have one on an X2 4400 system and it does a good job.
spathotan
2,390
Id say go to the Akasa like KyleSTL said, or the Zalman 9500 eventhough its overpriced. The Akasa isnt on your list but it is at the store you are shopping at.
spathotan
2,390
Remember the smaller the fan the more noise it will make. The 120mm fan on the Coolermaster will produce less noise than the 80mm on the VX. I say go with the coolermaster.
fatcat
517
It always depends on what you call cheap but anyways I own both the Thermalright Ultima and the Xigmatek s1283, they are both relatively quite with performances to booth. The Xigmatek is cheaper and comes with a fan which is not the game with the TRU.
KyleSTL
1,678
kel varnsen
27
if i'm reading this correctly, the big typhoon does very well in terms of noise. only worry, is it too big and heavy for the m-board and cpu?
spathotan
2,390
No youll be fine. With the exception of that Akasa, these things would not be sold if they were so heavy/horribly made that they damage motherboards.
