Hi Guys,
I bought am Alpha Pal 8045 with the Delta 80mm fan 4000 RPM
and 46.1 CFM. It's WAY loud. I'm using it with an Athlon 2000 XP but no overclocking in an Antec 1040 case.
Guys could you recommend me a fan that is quiet for this ?
Is the 80mm fan @ 28CFM from Quiet PC up to the task ? it's
only 20dB maybe not. What else can I use before I go insane.
Thanks
Thanks
