Need a replacement for my 7850 1 GB
Roger_MacClintock
8
Hello. It's time to replace my 4 year old Radeon 7850 1 GB.
My current PC:
CPU: i5-750 @ 3,5 Ghz (I can OC it to a higher clock speed if it helps)
GPU: Radeon 7850 1 GB
MB: MSI P55-GD65
Ram: 8 GB DDR3 1333
PSU: Corsair CX 430W 80+ Bronze
Monitor: Dell P2314H Full HD
1. Cheapest option:
Inno3D GeForce GTX 1050 Ti TwinX2 4GB GDDR5
ASUS GeForce GTX 1050 Ti Phoenix 4GB GDDR5
Gigabyte GeForce GTX 1050 Ti 4GB GDDR5
2. Pay more to get better RX 470
e.g. ASUS Radeon RX 470 4GB 256bit PCI-E DDR5 OC STRIX
3. Or spend a bit more money than 470 cost and buy RX 480/ GTX 1060 3GB.
Is my psu good enough for the RX 470/480/1060 3 GB?
Is my i5-750 good enough for those GPU or should i stop on the 1050 TI
The RX 470 is the best bang for the buck. If you can catch a deal its about the same price as most 1050ti's.
Video Card: Asus Radeon RX 470 4GB STRIX Video Card ($149.99 @ Amazon)
Total: $149.99
Generated by PCPartPicker 2017-04-03 19:27 EDT-0400
This one is $145 after rebate.
https://www.newegg.com/Product/Product.aspx?Item=N82E16814150781&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
