Need a replacement for my (gaming) mouse (right button starts to act up)
fry178
776
12
5,365
Needs to be a name brand, as others are not consistent enough in quality.
Loved the logitech G7, but cant use it while running wifi, the G9 was wired and way to short,
the G700 im replacing is ok, but i would love something a little bigger to rest the "whole hand" on it.
Maybe one thats adjustable or allows modding with 3D printed parts.
I've looked at a couple different ones from logitech/corsair/asus/cougar/razor etc,
but as with a lot of things, i dont want to have to buy all of them to try them out.
would love some feedback from ppl using any of the above..
for any recommendations:
i don't need
- higher than 3000 dpi
- polling beyond 1000Hz (usb ports are limited to 500 anyway)
(but no problem, if the mouse has it)
Needs to have:
- wireless, as i watch movies/listen to music and want to use the mouse couple feet away from pc (unless the mouse is "perfect 10" in everything else, then i might live with wire)
- at least 2 additional buttons besides left/right/wheel buttons
- and at least 2, better 4 on the left side of the mouse (dont need more than 4)
- should be able to run with (one) AA or 1-2 AAA battery
(2 AA only if mouse is sub 110gr/3.88oz)
thanks for any info
I don't know mouse specs from the top of my head, but I would point you in the direction of the logitech g404. Not sure if it fits your needs, I just know it is a great wireless mouse. Stay away from razer mice.
