I'm debating whether I should I go with a top of the line air-cooler that can fit in my case, which can fit a cooler up to around 6 inches, or with a water cooler such as the Corsair H100i 240mm. The thing is though, the case has an optical drive that I'm currently using, which would move the radiator on the AIO down below the pump, which I know isn't that good for the pump's lifespan. So I want to know if I should get an AIO and risk an earlier pump death, or get a top of the line air-cooler. Right now, I'm using the stock cooler that came with the Ryzen 7 2700x, and I'm a little dissatisfied with how loud the noise is during gaming. I'm getting temps up to 85*C, and the fan on it is a little loud when it gets up to that temp, which is why I'm trying to upgrade the cooler. Another thing is that the current case I have can't have the AIO Rad mounted on top, because there are clearance issues with the motherboard and the optical drive.
Specs:
MOBO: Gigabyte Aorus Pro Wifi B450
CPU: Ryzen 7 2700x (Stock Settings, PBO on)
CPU Cooler: Wraith Prism (Stock Cooler)
GPU: RTX 3060 Ti (Gigabyte Gaming OC Rev. 1.0)
RAM: Vengeance RGB Pro 3600mhz 4x8 (Underclocked to 3200 mhz due to stability issues)
PSU: Seasonic Focus GX-850 Gold
Case: DIYPC TG8-BR
Specs:
Case: DIYPC TG8-BR
