Need a suggestion for computer case
Arun Satyal
21
Hi, I'm going to build a PC as following specs but I don't have any idea that I should use normal ATX casing or casing with fans on the front, top and rear?
Core i7 4770K
EVGA GTX 760 SC PCIe 3, DDR5 2GB with ACX cooling
32GB RAM (4x8GB)
Gigabyte GA-Z87X-D3H
256gb SSD
750w corsair PSU
I use my computer mostly for graphic design web design and sometimes video editing learning stuffs. Im not gamer but sometimes I play a game too. And I'm not overclocker :)
as long as it has one intake fan, and one exhaust fan... which they almost all do.
you'll be fine if you're not a gamer and not into OC'ing.
i'd pick a case you find visually pleasing, since you will be looking at it every day.
if you're an apple fan, you're probly into the 'white' look.
maybe the thermaltake a31 chaser snow/white edition
Thank u for your suggestion :)
