Can someone give me a recommendation for a UPS around the range of 800 to 1000 watts for a price of 100-150$? I need one that will last for about 10-15 minutes before going off.
Specs if need be, I dunno:
980TI, I7 4790K, 16GBs Ram DDR3.
To get an accurate estimate of runtime, you really need to know measure much power your system uses when running full bore. I put your components into a power supply calculator and got about 600W peak usage. You can take that to APC website and get estimates for runtime. I don't think you can get 15min runtime from $150 UPS...
Hey, thanks for answering.
After searching for a bit I came across these 2: http://
They both have an output of 660 watts which should be enough for my PC, though one costs 83$ and the other 100$. Is there any real difference? If so, what should I get?
I'm not familiar with UPSs, so I'd really appreciate your help..
