Need a very good power supply
Somebodyxxx
7
Hello all!
I have bought some parts for my new pc:
i7 4790k
Asus Maximus VII Hero
Asus Strix gtx980ti
Corsair Vengeance 1866mhz (2x8)
Intel 240GB SSD 535 x 2
WD Caviar Green 4tb x 2 (storage)
WD Caviar Black 1tb x 2
Coolermaster V8 GTS (cpu cooler)
As you can see I need a power supply to power everything up
Also I will add one more asus strix gtx 980ti later and overclock a little (the CPU and the GPUs)
There are only theese power supplies:
Xilence 1000W Gaming Edition
XFX Core Edition 80+ 850W
Enermax 1000W Revolution 87+ Series,80+ GOLD
CORSAIR RM1000
SEASONIC 1050W
oh, didn't realize you had a certain range of products.
in that case go with SEASONIC 1050W. same applies. seasonic actually makes the unit i previously suggested (which is the one i own 😀 ). very high quality.
Seasonic is great but not the only good ones. Superflower, Delta, and perhaps Enhance are also top notch platforms.
Thanks for the quick reply :)
Benjiwenji, do you see a delta, superflower, or enhance built psu in his list? I sure dont. In the list he posted the 2 Seasonic built units are the best.
The xilence is Andyson so it's most likely garbage.
The Enermax is made by Enermax and isn't bad just not as good as the seasonics.
The Corsair RM is made by CWT and isn't very good.
I was just trying to help. To be honest, I missed his list the first time around. Didn't mean to hurt your ego.
