Need a VERY small case for my ATX build
rhsnipes
148
I just moved into a smaller living space and my NZXT Phantom is hogging precious real estate. The case has more empty air than it has circuitry. My components stay super cool at like 30-50 degree range. I want to replace the case with something aesthetically robotic and compact. I have a normal ATX board, a 120mm cpu fan, and a 282mm GPU.
I was looking at these:
https://www.amazon.com/dp/B00VRKVT34/ref=psdc_572238_t2_B01D205IXS
https://www.amazon.com/RIOTORO®-CR1080-Compartment-Support-Dedicated/dp/B01D205IXS/ref=sr_1_1?s=pc&ie=UTF8&qid=1469466267&sr=1-1&keywords=small+atx+case
[strike]I would like to buy from newegg that way my computer part order history can be all in one place. [/strike]Any help and I would be grateful!
A 'small' ATX case is a tough find really.
I see this Rosewill I5-397. It's very similar in height & width as the AeroCool you linked, but it's >1" deeper.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147234&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Obviously, discard the 'included' PSU.
Reactions: rhsnipes
Thanks for the help. I think It's nice to bounce an idea off of someone, really helps. I'm going to get the Riotoro. The rose will looks to be a sweet price point for solid design, only a little basic.. aesthetically. I'd like to have a open air case if it could be small.
I like how a build can look almost like an electric metropolis!
