Question Need a way for a Verbatim Blu-ray disc on a LG Blu-ray writer (WH16NS40) to write at maximum speed of 16x ?
Mar 2, 2021
The LG 16x Blu-ray writer WH16NS40 I bought a couple of years ago use firmware version 1.03. For a couple of years, I use single-layer data blu-ray discs writing at a slow 8x speed. I recently bought a 50-pack of Verbatim single-layer 25GB Blu-ray discs that can write at up to 16x, and it's the only brand in the market that can write 16x blu-ray discs. I use Cyberlink Power2Go11 to write data to DVDs and Blu-rays.
However, when I inserted that new writable blu-ray, the program will only allow up to 12x maximum speed, not 16x!! What gives in to the restriction? Do I need a different type of software to make writing at least 16x possible, or the worst case scenario is to roll back the firmware one version to make 16x blu-ray writing possible (along with 4K movie viewing compatibility)? I really don't want to roll back the firmware as it's difficult to do so and it needs to be done in Windows 7 32-bit OS.
Did the old firmware work at 16x speeds? Does not sound like you ever used that speed, so thinking the firmware change can do it is a bit faulty.
Other software, sure that may help, Nero is good but can be expensive.
Could also be an issue of those disks.
Really I would stick with the slower speed, over the years I have learned that the faster the media is written the more chances there are of errors during play back. Last time I burned disks I was using 4x speeds pretty much 100% of the time to maintain good compatibility when playing them back.
Reactions: Phillip Corcoran
Well using ImgBurn, this is what the device info said, despite supporting a max read and write speed of a single-layer BD-R at 12x. I could try forcing a 16x speed, but I don't think the hardware will allow it.
HL-DT-ST BD-RE WH16NS40 1.03 (RAID)
Current Profile: BD-R
Disc Information:
Status: Empty
State of Last Session: Empty
Erasable: No
Free Sectors: 12,219,392
Free Space: 25,025,314,816 bytes
Free Time: 2715:27:17 (MM🇸🇸FF)
Next Writable Address: 0
MID: VERBAT-IMe-000
Supported Write Speeds: 4x, 6x, 8x, 10x, 12x
BD Disc Information:
Disc ID: VERBAT-IMe-000
Disc Type: BD-R
Disc Size: 120 mm
Disc Class: 0
Disc Version: 1
Disc Time Stamp: 03/2010
Number of Layers: 1
Layer Type: Writable
DVD Layer Present: No
CD Layer Present: No
Channel Bit Length: 74.50 nm (25 GB Per Layer)
Push-Pull Polarity: Positive
Recorded Mark Polarity: HTL
BCA Present: Yes
Maximum Transfer Rate: Not Specified
First PAA of Data Zone: 131,072
Last PAA of Data Zone: 1,658,494
Performance (Write Speed):
Descriptor 1...
-> B0: 0x00, B1: 0x00, B2: 0x00, B3: 0x00
-> EL: 12219391 (0x00BA73FF)
-> RS: 53,952 KB/s (12x) - WS: 17,984 KB/s (4x)
Descriptor 2...
-> RS: 53,952 KB/s (12x) - WS: 26,976 KB/s (6x)
Descriptor 3...
-> RS: 53,952 KB/s (12x) - WS: 35,968 KB/s (8x)
Descriptor 4...
-> RS: 53,952 KB/s (12x) - WS: 44,960 KB/s (10x)
Descriptor 5...
-> RS: 53,952 KB/s (12x) - WS: 53,952 KB/s (12x)
I use cdburnerxp, im able to force burns at different speeds only did it once, but it was at a lower speed. might be worth trying. but dont do a bunch like that, do one and test the disc out and make sure the burn was good/data is fine, and if all si well then do all of them like that.
Have you tried forcing a 16x burn? I'm curious as to the result.
I tried forcing burning 12x on an older 8x BR-disc using IMGBurn, the hardware won't allow it as it sticks to 8x burning. For 16x, I don't think it's possible unless I roll back the firmware one version below for that hardware.
