Need advice 5770 vs r7 250
luispt
5
Hello,I need an advice for buying a new graphic card, my system is a ahtlon x2 4800+ 2.5 ghz with 4gb of RAM dd2 800mhz and a psu of 550w I have 80€ to spend!
In terms of performance, it should be similar. So let's look at other factors
Since the R7 250x is newer, it may have better compatibility with newer games. Anyway, if you do manage to find a HD 5770, it would most probably be used and all dusty.
and what do you recomend in a budget of 80-100€ max?
Benchmarks~
I'm no expert in CPUs, and I'm not sure about bottlenecks, but I watched a video from Tek Syndicate on YouTube, and they states that bottlenecks aren't usually so common. Tomshardware has also paired a Pentium G3258 with a GTX 770 in one of their build articles, so if a low end CPU like the Pentium could work with the high end GTX 770, I don't think there should be any bottlenecks in your case.
Then again, I'm no expert, and I have no actual proof. I may be wrong.
