[SOLVED] Need advice about motherboard USB header
Sep 3, 2020
Hello, I am planning to build a PC with:
  • Motherboard: ASRock B550 Steel Legend
  • Case: Gamerstorm Macube 310P
On the case, there are 2 USB 3.0 ports.
Meanwhile on the motherboard, there is only 1 USB 3 header. The mobo spec says that the header supports up to 2 USB 3 ports.
My question is, how do I connect 2 USB 3.0 ports from the case to 1 USB header on the motherboard?
I am assuming it is possible because the mobo spec says so. Or is that even possible at all?
