So im finally building my very first pc, for gaming purpose. Im not looking for something like pc master race but just normal ordinary gaming like battlefield and stuff. Anyone can leave a comment of any suggestion for my planned built would be appreciated. Thanks.
the build is as below:
Case CORSAIR SPEC-03 COMPACT GAMING CASE - RED LED
Processor (CPU) Intel® Core™i3 Dual Core Processor i3-7320 (4.10GHz) 4MB Cache
Motherboard Gigabyte Z270X-Ultra Gaming: ATX, LG1151, USB 3.1, SATA 6GBs - RGB Ready!
Memory (RAM) 8GB Corsair VENGEANCE DDR4 2133MHz (2 x 4GB)
Graphics Card 4GB NVIDIA GEFORCE GTX 1050 Ti - DVI, HDMI, DP
1st Hard Disk 1TB SATA-III 3.5" HDD, 6GB/s, 7200RPM, 32MB CACHE
M.2 SSD Drive 256GB M.2 2280, SATA 6Gb/s (546MB/R, 477MB/W)
DVD/BLU-RAY Drive 24x DUAL LAYER DVD WRITER ±R/±RW/RAM
Memory Card Reader USB 3.0 EXTERNAL SD/MICRO SD CARD READER
Power Supply CORSAIR 350W VS SERIES™ VS-350 POWER SUPPLY
Power Cable 1 x 1 Metre UK Power Cable (Kettle Lead)
Processor Cooling CoolerMaster MasterLiquid Lite 120 High Performance Liquid Cooler
Thermal Paste ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND
LED Lighting 50cm RGB LED Strip
Sound Card ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD)
Wireless/Wired Networking WIRELESS 802.11 AC1300 867Mbps/5GHz, 400Mbps/2.4GHz PCI-E CARD
USB Options MIN. 2 x USB 3.0 & 2 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
update1.0
Approximate Purchase Date: still hasnt choosen when to buy it yet but not so soon.
Budget Range: approximate 800euro- 1300euro
System Usage from Most to Least Important:gaming is more important, sometimes work
Parts Not Required: just the pc is okay
Preferred Website(s) for Parts: pcspecialist
Country: republic of ireland
Parts Preferences: i less prefer amd parts, but considerable
Overclocking: no, i dont want risk
SLI or Crossfire:no
Monitor Resolution:1920x1080
Additional Comments: pc rig with lights if possible, a little fan noise is okay
update1.0
SLI or Crossfire:no
