Hi, going to build my first PC soon, not really a great expert at it but I know some things.
Going to use my old CoolerMaster case and old storage.
PC parts:
Processor: http:// (Ryzen 5 1600) (not OC'ing it)
Graphics Card: (Going to be OC'ing it a bit) http:// (GIGABYTE GeForce GTX 1060 6GB (might be 3GB, not sure yet)
Motherboard: http:// (GIGABYTE GA-AB350-GAMING 3)
RAM: 2x4GB RAM (2400 most likely), haven't really picked the brand, it confuses me that for every RAM it says it supports some Intel shit, don't know if it goes with AMD too, let me know
Power Supply: Haven't picked it, I need help determining how many W I need, guessing around maybe 500W but not sure, need help with that aswell.
Also, if there's any part I need, or some accessory that I missed out (extra fans, idk), let me know, not really an expert in computers, but I know some stuff.
Now, I think it's okay, let me know, or suggest something that you think might be better with the build. Not sure for the GPU, if I need the 6GB one, will 3 be enough? Should I pick the 6 pin GPU, or the 8 pin one?
Are the 2 more pins needed? I'm only going to OC the GPU quite a bit, wanna get around maybe 7 more FPS, don't know if this is the right mobo for that (I think it should be good but not sure. Don't wanna damage the GPU, so I wanna make sure the mobo and everything will be able to OC it properly. Let me know if I should make some changes. As I said not really a great expert since this is my first PC build, so would really appreciate some (expert) help.
Also some games I'm going to play on the PC: PUBG, Overwatch, GTA V, other shooting games, and some singleplayer games, and some other games in the future. I'm a bit worried If I pick the 3GB VRAM that I won't have enough for high demanding graphics games in the future, or even for these games. As for the graphics in game, probably will go for (High)Very High, Ultra, whatever I can max out that gives good framerate. I think the right one is 6GB, for my needs, but let me know.
Thank you very much for your time, for reading this essay lmao, and thanks a lot in advance!
PC parts:
