Hi !
I would like to get comments or advice on my next build. It will be used as a gaming pc at 1440p 144hz mostly.
I want to buy :
CPU : i5-6600k (going to overclock as high and stable as I can)
CPU cooler : Corsair H105
Motherboard : Asus Z170-A
Case : Fractal Design Define R5 (might add fans to the case, depending on temps)
Memory : G.SKILL Ripjaws V Series 16GB (2 x 8GB) DDR4 3200 14-14-14-34
Power supply : EVGA SuperNOVA 1000 G2 Modular 1000W Power Supply (SLI futureproof)
Already have :
SSD : Samsung evo 840 256gb
HDD : 4tb
Monitor : Benq XL2730z 1440p 144hz
GPU : EVGA GTX 1070 SC
If you suggest something else, I would like the price to be worth it
Thank you !
I want to buy :
Already have :
HDD : 4tb
Thank you !
