Hey. After some reading:
this is the build:
CPU: Intel Core i5-3570K
Motherboard: ASRock Z77 Extreme4
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600
Storage: WD Black Cavier 1TB
Video Card: Radeon 7870
Case: (will decide on-spot)
Power Supply: (not sure)
1) Is the build balanced?
2) What im not sure about is which mobo should i get. The one i selected, is it good enough or should i go for Gigabyte, Intel, Asus etc
3) My mind is fixed on the CPU & GPU I mentioned. Although I wanted to know which Manufacturer I should opt for? Theres a variety in my market. Saphire, EVGA, HIS, MSI, GIGABYTE, ASUS etc.
4) how much PSU would i need for this rig? and which company?
5) also would i need a CPU Cooler? if yes, which one?
6) im trying to keep the build under $800 - $850.. Because I'll also be buying a Monitor. 22" Max.. Need recommendations for that as well.
Kindly answer my questions. Thankyou
this is the build:
