Need Advice For a Light Weight Portable Laptop or 2-in-1 under 25000 INR
Rohail Sk
54
I want a Light Weight Portable Laptop of good quality under 25000 Indian rupees.
Main purpose for college, some light java coding and running virtalbox.
I already have an hp-pavilion g6-2237tx for some heavy workload.
I have also sorted out these options suggestions which one is better:
1. Asus E200HA-FD0004TS
2. http://www.amazon.in/Asus-E200HA-FD0043T-11-6-inch-Integrated-Graphics/dp/B01N6SNO62?_encoding=UTF8&ref_=cm_cd_al_qh_dp_t
3. HP Atom
So any Suggestions. Or any other recommendation of laptops from your side would be very helpful. Thank You.
Preferred Websies:
Amazon.in
Flipkart.com
Snapdeal.com
Out of the 3 I would say the one with the most ram is the best. In terms computational speed I don't think you will notice a speed difference. For normal purpose the 4 gig of ram will be better as you will be able to multi task more.
