Need Advice for a Photoshop CS5 new build
This is my first build, and your advice is greatly appreciated. I have thoroughly enjoyed reading the advice you have given others, and while I did see previous posts for building a computer for Photoshop, I did not see any recent posts.
This computer is primarily for editing photos with Photoshop CS5, with a bit of video editing. It will also be used for the internet, and at times for watching TV (cable). It will not be used for games.
I also use (rarely) an old Nikon negative scanner that uses SCSI. (Nikon Coolscan III)
Approximate Purchase Date: Within the next month or two
Budget Range: $1000 - $1500 (although it is flexible)
System Usage from Most to Least Important: Photoshop CS5, Internet, watching TV/Cable
Parts Not Required: keyboard, mouse, speakers, and monitor (For now, I do not need a monitor, although I would be happy to hear your suggestions for good 24- 30" monitors that have excellent color representation (not a gaming computer)
Preferred Website(s) for Parts: newegg.com, ncix.com, TigerDirect
Country of Origin: Canada
Parts Preferences:
CPU I was originally thought of the Intel Core i5-2500, but I am now leaning towards the i7-2600 as it seems photoshop will take advantage of the extra cores. I was not thinking of the K series, as I will not be overclocking.
Heat Sink As this is my first build, I am hoping for a heat sink that is easy to install and does not get in the way of adding memory, etc. (I have been getting worried reading reviews how the stock heat sinks are either not good enough, or how heat sinks are awkward to install, or get in the way of adding memory)
MOBO A reliable motherboard is my main concern. I had thought of Intel's DX58SO2 board, but I do not see it available for purchase. Various ASUS boards have also caught my eye. I must admit, while it was an education to read the comments on the various boards, I am getting a bit worried about people having troubles installing heat sinks or a second set of memory, etc. Your advice here is greatly appreciated.
Memory Good reliable memory, at least 8 Gigs, perhaps 16
Hard Drive Good and reliable hard drive
Removable Hard Drive Bay For quick and easy back up of my images
Graphics Card This is not a gaming computer, but I do want a good card that will drive a single monitor. (I will be getting a new 24 - 27" monitor in the coming months, maybe 30")
Tuner Card Unless there is a good all in one graphics card
SCSI Card I have an old Nikon negative scanner that I rarely use, and thus I am not ready to buy a newer one. It connects to a SCSI card, and the cable that connects to the computer is a 25 pin connector.
Card Reader For compact flash cards, as well as SD and SD-H cards
Power Supply Again a good and reliable power supply. I do not plan on adding a second graphics card, and the only addition I can foresee is doubling the memory in the future.
Case Another place I had a good time reading. Ideally an easy to work with case, that is not too big. I have thought of the Antec 300, but I am open to suggestions. Having front USB 3.0 ports would be nice for the future, but not essential.
OS Windows 7 Professional 64-bit
Overclocking: No
SLI or Crossfire: No
Thanking you all in advance.
Parts Preferences:
Overclocking: No
