Need Advice For A Short ATX12v PSU For A Mini Itx Build!
d3th5150
83
So recently decided to start buying parts for a new PC. I started with the case, since this one has had my eye for a while.
After receiving the case I measured the inside case from where the PSU would be screwed in, to where the mother board standoffs are. There is 6 Inches between the two points give or take about a few mm for the motherboard itself.
So I'm just wondering if anyone would know of a PSU that is modular, and is about 5.5 inches or less in length?
If one can be found to be short enough, it might not have to be modular. But it would have to be 4 inches or shorter for that.
It does not have to be powerful. I do not need anything above 550w.
I only plan to get a GTX 750Ti for the build. And if I do upgrade, I would only get a 970, nothing more.
Oh one last bit of info, if you look at the side of a PSU that has the female connector for power, the right side of it, the way your facing then, would be the side the PSU will lay on inside that case.
Thanks for any answers in advance!!
EDIT: Still have not found anything that would be a good match. I found a video of a guy that built a PC in a Raidmax Troy case. It's the exact same case,just different brand. He used a Seasonic X750. But his cables looked like they were in a bad way.
Here is the video: https://www.youtube.com/watch?v=z7WVU_yui_I
As you can see he squeezed everything in there basically. As for the PSU that one Is out side my budget. (trying to stay under $95 on the PSU)
I was actually thinking on this one before. But its 5.91 inches deep and i have 6 inches of room before the standoffs.
However the seasonic xfx looks promising. What would be the best CPU and GPU setup for it without pushing it over the edge?
Currently im thinking on going with haswell and starting with a 4460 i5 and a 750ti. Just to start with.
Other options,
http://pcpartpicker.com/parts/compare/cooler-master-power-supply-rs550amaag1s1%2Csilverstone-power-supply-sstsx500lg%2Csilverstone-power-supply-st45sfg/
the Silverstone psu's are SFX,but come with a bracket that makes them fit in an ATX case.Being SFX makes them even smalller.
The cooler master is as short as ATX psu's come,it's exactly 5.5" deep.
