Need advice for a upgrade
G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.nvidia (More info?)
Hello. I have pentium 3 Micron. It has a nividia Geforce ultra2 for a video
card. Someone advised me to upgrade to ti4200 128 ram. My children want to play
the new games out there now. Will a ti4200 meet the demand?
Ken Williams
raj
143
well, if you upgrade to that ti4200 card their are bound to be bottle necks
in system and mainly your Pentium 3 would be bottle necking that gf 4 ti4200
card. Your Pentium 3 FSB is 133, your ram is probably sd 133? what's your
system specs, so we can give you a even more clear view on a worth while
upgrade, if your budget is a bit more wide I would go for a nforce 2 setup
with a 2500+ AMD athlon xp, with 512 ddr 400, and then slap in a gf 4 ti
4200 :) only my 2 cents.
"Ken Williams" <Ken_member@newsguy.com> wrote in message
news:cchd1302p50@drn.newsguy.com...
video
play
> Ken Williams
G
Guest
Guest
Define "the new games out there'. If you mean Doom 3 and Half Life 2, No,
your system is too slow and old to handle the graphics load. If you mean
run of the mill games from the last couple of years, then yes the Ti4200
will serve the purpose. But, remember, the 4200 is NOT DX9 capable so it
will not play any of the newest games from this year very well.
DaveW
video
play
> Ken Williams
G
Guest
Guest
video
play
> Ken Williams
I'm afraid that just changing videocard does not able your kids to play
latest games out there.You dont specify any system specs so its difficult to
say if upgrading to GF 4200 is sensible thing to do.Nvidia GF4200 is not top
of the line videocard these days but it will give you significant
performance boost if your Pentium 3 cpu is running around 1 Ghz but if your
cpu is running under 500 Mhz dont bother to buy the card.So if you got high
end Pentium 3 system it might be sensible to upgrade to GF4200 but your
system would still be low end in games point of wiew.
Juha Suoranta
G
Guest
Guest
"DaveW" <none@zero.org> wrote in message
news:eek:z%Gc.41924$XM6.20185@attbi_s53...
BS from DaveW yet again. The Ti4200 is not a DX9 hardware card, but it *IS*
capable of running DX9 games as it has DX9 compliant drivers that will run
on it. And "very well" is hardly a measurement that someone could use to
determine if the card would do what they needed - for instance, my Ti4200
runs FarCry at around the 45-55fps mark (which is smoother than it sounds,
very high frame rates are not a requirement for most games, FC doesn't
really start to feel "slow" until it drops to around 25fps) with medium
graphics settings which I personally would not class as "not playing very
well"
Dan
G
Guest
Guest
In article <xXYGc.36$Sc.312@news1.mts.net>, Raj says...
>video
>play
>> Ken Williams
Heres the specs I think you want:
M.B- Aurora-gigabyte 7DX with IC (Millenia Max XP)
AMD T-Bird Athlon 1.2 GHZ 200 FSB
256 MB of RAM DDR
I'm running XP
The machine is 3 years old I think. It was given to me. The fans were replaced
and Me was replaced with XP. 128 DDR RAM was added. I have some money to spend
to upgrade. Thank You
G
Guest
Guest
On 7 Jul 2004 10:48:19 -0700, Ken Williams <Ken_member@newsguy.com>
The Ti4200 is a FINE classic 2yr old card.... but it's not going to
run much faster than your current P3 system... Your P3 doesn't even
push the GF3 card....
And for todats games? YOu'll need to pop for a whole system... and
then the video card.
Remember: In the USA - it is dangeroud to draw or write about Heir Bush in a negative way. The police or SS are called, people threaten to kill you. (What country is this again?)
- Fahrenheit 9/11 - Unless you see it for yourself, don't call it "a bunch of lies"... that would be unAmerican.
- White House blows cover of an undercover agent because her husband said there were no WMD (before the USA started the war) - her job was finding terrorist.
God bless the land of the free. Where you can burn the Constitution... Ashcroft does it every day.
G
Guest
Guest
In article <ucdpe059nj7uia9htlv2lg4oios5nkp6nh@4ax.com>, Darthy says...
>wrote:
(everything else snipped)
So what would I be looking for in a whole system to play todats games.
Thank You
raj
143
well I would suggest add another 256 of ddr, you should try to find out to
see what's the fastest processor your board can handle, chances are that it
can run up to the 266fsb, therefore you maybe able to run up to a 2400+ on
that board, and then your ti4200 would be running at decent performance.
news:ccj05f01a7v@drn.newsguy.com...
necks
ti4200
setup
> >video
to
> >play
> >> Ken Williams
> 256 MB of RAM DDR
> I'm running XP
replaced
spend
G
Guest
Guest
I better send that memo to my TI4800, because it plays almost any game out
there at the highest settings.
G
Guest
Guest
I would get the Ti4600 vs the Ti4200 a lot better card. You can pick it up
on Ebay for around $50.00. Also I would upgrade the computer. Can you or a
friend install a new motherboard and CPU? If not check around for a cheap
local shop or get a barebones pc on Ebay or Multiwave.com If you get a
Athlon motherboard and 2500 cpu it would be a very nice upgrade.
A barebone would require you or a friend to move the memory and hard drives
to your new computer.You can also pick up a 256 or 128 meg memory upgrade
pretty cheap on Ebay. Good luck.
Here is a nice one for only $219 + shipping:
AMD XP2600 ASUS A7V8X-X DDR400
news:ccj0kf01bc3@drn.newsguy.com...
> Thank You
