Need advice for choosing the right parts for my new PC
opeth81
6
Hi..
i want to build a new PC. i am not a gamer and i want to build something like HTPC with a MIDI TOWER Case.
i am not sure witch motherboard socket to choose..
Thinking for socket 1150 and i have found some parts and i want your opinion...
CASE: MS-TECH CA-0300 HORNET NG BLACK/GREY WITH RED LED FANS
MOTHERBOARD: ASUS H87 PLUS RETAIL
CPU: INTEL CORE I3-4330 3.50GHZ LGA1150 - BOX
RAM: G.SKILL F3-12800CL9D-8GBXL 8GB (2X4GB) DDR3 PC3-12800 1600MHZ RIPJAWSX DUAL CHANNEL KIT
GRAPHIC CARD:ASUS GTX650TI-1GD5 1GB GDDR5 PCI-E RETAIL
HDD: SAMSUNG MZ-7TE120BW 840 EVO SERIES SSD 120GB 2.5'' SATA3
PSU: INTER-TECH SL-550W 550W PSU
So what do you think guys?
Thanks
Aspire77360
566
Looks all good, apart from I, personally, would go with an i5 processor. As you're not a gamer, the better motherboard might be something like the Asus H87 series, which would allow you to fit a graphics card if you decide to.
opeth81
6
yes i know that i5 has more advantages but do i really need it? as for the motherboard i had chose Asus h87 plus and for graphic card asus gtx650ti.. what do you think? thanks
Aspire77360
566
Good point, didn't see those!!! What is your budget?
opeth81
6
Thanks.. i will check it out!
opeth81
6
Aspire77360
566
In which case, your build is about right, apart from the H87 series of motherboard apparently only supports Crossfire(AMD) and not SLI(Nvidia) graphics card, which would affect your rig. I would recommend changing to a motherboard with the Z87 chipset. The other features of the Z87 is that they allow overclocking, but as you don't intend to overclock, it renders the point mute.
opeth81
6
Thanks.. didn't know that
Aspire77360
566
No prob
opeth81
6
any Z87 ? ASUS Z87-K RETAIL is that ok?
Aspire77360
566
No prob
