Need advice for finishing a $1000 Gaming Build!
Parsnip
91
Hi, I am putting the finishing touches up on this new gaming build. This is my first ever build and I'm in need of your guys help in making sure all the parts are compatible and that I'm not missing anything (or any last minute changes you may recommend)! My budget is around $1000 USD (I've gone a little bit over :na: ) and I added in a new monitor (doesn't really count in the budget). I do not need an OS, Speakers, Keyboard, or Mouse. I hope you can help and thanks for taking a look! :D
Case: NZXT Phantom PHAN-001BK Black Steel / Plastic Enthusiast ATX Full Tower Computer Case $140
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146068
HDD: SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive $55
http://www.amazon.com/gp/product/B002MQC0P8/ref=ox_sc_act_title_2?ie=UTF8&m=ATVPDKIKX0DER
GPU: EVGA GTX 570 $340 - $25 MIRB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130595
PSU: XFX Core Edition PRO850W $120- $20 MIRB
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207011
CPU+Mobo: I5 2500k + MSI Z68 LGA 1155 Mobo $375 - $20 MIRB
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.674899
CPU Cooler: COOLER MASTER Hyper 212 $30
http://www.amazon.com/gp/product/B002G1YPH0/ref=ox_sc_act_title_1?ie=UTF8&m=ATVPDKIKX0DER
Ram: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 $70
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
CD Drive: LG CD/DVD Burner Black SATA Model GH22NS70 OEM - OEM $20
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136238
Total = 1150
-65 MIRB
=$1085
Monitor: ASUS VH238H Black 23" Full HD HDMI LED Backlight LCD Monitor w/Speakers 250 cd/m2 ASCR 50,000,000:1 $190-$10 MIRB= $180
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236117
z_4
367
How about an SSD at around the same budget? .Here a build which incorporates one :
CPU & OPtical Drive: $226- i5-2500K & Samsung
Motherboard & SSD : $225- Gigabyte Z68X UD3 & Crucial M4 64GB
PSU & RAM : $175- Thermaltake Black Widow & GSkill RipjawX 2X 4GB(80plus bronze certified , modular & cheap memory has $10 off with promo code)
(optional, you can have NZXT case also) Case & HDD: $205- Corsair Graphite 600T & Samsung Spinpoint 1TB
GPU: $325- EVGA GTX 570
Total (Excluding Rebates): 1155 USD
Rebates : 65 USD
Cooler : Go for Hyper 212 from amazon
Monitor you may want to look into :
$200-Samsung BX2331 23" LED Backlit(Reason: $30 off w/promo code EMCKCJE72)
so it will cost $170.
If you are not much into 2ms response time look at this one:
$150- Acer 23" LED Backlit (1920X1080)(it has 5ms response time)
Parsnip
91
I personally don't see the use in SSD technology so far XD.
