Need advice for my first $900 gaming build
fbi_freeze
Commendable
Jan 23, 2017
5
From Philippines, prices are converted PESO to USD.
Will play at HIGH 1080p 60fps (think Witcher3, Tomb Raider).
Will NOT overclock.
Will buy this June or July.
Help me choose a smarter/better bang for buck/cheaper build.
Intel i5 7400 $187
MSI H270 Tomahawk Arctic $155
AORUS RX580 8GB $280 or Sapphire Nitro+ RX580 8GB $302
Kingston Hyperx Fury DDR4 2400MHz 1x8GB 69$
WD Caviar Blue 1TB 7200RPM
NZXT S340 $80
Seasonic G650W 80+GOLD semi mod $99 or the 550w version
Here are some suggested bang-for-the-buck builds:
Intel Build (locked, non-OC):
CPU: Intel Core i5-7500 3.4-3.8 Ghz 4-core Kaby Lake Processor (P10190.00 @ DynaquestPC)...
Get a i5 7500 if it's not a ton more usually Worth the extra here in the USA. You can drop to a b250 motherboard and save a few bucks to upgrade the processor. I'd also consider a 2*4gb Memory kit to take advantage of dual channel. The 550w sp
PSU would be plenty for that build
It will cost me an aditional $20 bucks for buying i5 7500. Is it worth it?
Buying a 1x8gb ram to upgrade to 2x8gbs in the future. But if 8gb is enough then ill buy 2x4gb.
Here is a Ryzen build that should save a bit and being a 6 core more future proof. I went with a 750w so it can handle 2 580's if the need arises.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor ($195.69 @ SuperBiiz)
Motherboard: MSI - X370 SLI PLUS ATX AM4 Motherboard ($120.98 @ Newegg)
Memory: Corsair - Vengeance LPX 8GB (2 x 4GB) DDR4-3000 Memory ($66.99 @ Newegg)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($48.44 @ OutletPC)
Video Card: Gigabyte - Radeon RX 580 8GB AORUS 8G Video Card ($260.99 @ SuperBiiz)
Case: NZXT - S340 (Black/Red) ATX Mid Tower Case ($69.99 @ B&H)
Power Supply: SeaSonic - 750W 80+ Gold Certified ATX Power Supply ($99.99 @ NCIX US)
Total: $863.07
Generated by PCPartPicker 2017-06-13 23:37 EDT-0400
Motherboard: Gigabyte GA-B250M-HD3 (P4300.00 @ DynaquestPC)
Memory: Corsair Vengeance LPX 8GB Dual DDR4 2400 CL14 (CMK8GX4M2A2400C14) (P3940.00 @ DynaquestPC)
Storage: Western Digital Caviar Blue 1TB WD10EZEX (P2350.00 @ DynaquestPC)
Video Card: Gigabyte RX 580 8GB Gaming (GV-RX580GAMING-8GD) (P12750.00 @ DynaquestPC)
Case: Tecware F3 Mini Tower Gaming Case usb3.0 (P1290.00 @ DynaquestPC)
Power Supply: Seasonic M12II-520 EVO 520w 80Plus Bronze Fully Modular (P3350.00 @ DynaquestPC)
Total: P38170.00 (or ~$763.40)
Ryzen Build (possibility to OC in the future, but you can choose not to):
CPU: AMD Ryzen 5 1600 3.20-3.60Ghz 6-Core Processor (P11150.00 @ DynaquestPC)
Motherboard: MSI B350M PRO-VDH (P4690.00 @ DynaquestPC)
Memory: GSkill Ripjaws V 8GB Dual DDR4 3200 (F4-3200C16D-8GVKB) (P4750.00 @ DynaquestPC)
Total: P40330.00 (or ~$806.60)
* If you want to play Witcher 3 and other AAA games in Ultra Eye-Candy Details on 1080p at constant 60fps, consider getting a GTX 1070 if your budget still permits (instead of the RX 580 / GTX 1060). If lowering graphics settings is okay with you for acceptable frame rates, then the RX 580 / GTX 1060 is sufficient.
How about his operating system? Isn't Windows 10 compulsory on 7th generation processors?
And why that case?
Thank You! Im strongly considering the Ryzen 5 1600, then choosing a b350 and 550w psu to cut expenses.
Why 3200 MHz RAM for the AMD build though? Thanks
You're welcome.
Ryzen builds do benefit from faster RAM speeds:
https://www.eteknix.com/memory-speed-large-impact-ryzen-performance/:
