hey guys so i need you're advice on what i should upgrade next but first here are my comps specs
Mobo: MSI: MS-7758 (http://us.msi.com/product/mb/Z77A-G43.html) link so you can see the chip set and what not
CPU: intel I5-2320 OC to 3.2 by my mobos default oc software
RAM: 16gig @1333 DDR5 ofc
CASE: coolmaster storm enforcer it is water cooling ready
GPU: Nvidia GTX 760 with 4 gig of Vram
HDD: 1TB seagate @7200 (or 5600 not sure)
OS: windows 7 64 bit
Power supply is a 700 watt
now i was wondering what would get me the biggest bang for my buck in terms of upgrading.
i have a budget of about $ 300 so try and keep it in that ball park range i look forward to you're guy's suggestions
hey guys i just realized while reading some of the first posts that i had my GTX 760 in the pci express 3.0 4x slot and not the 16X what kind of performance increase will i see when i switch it over here in a bit?
