Question Need advice for pc upgrade
Dec 7, 2020
I have £160
im looking to upgrade from a bad airflow acrilic case. I am looking to make the full pc to sync with RGB fusion. I would like to know if this is good for the budget and if the fans would fit the radiator + if everything syncs in RGB fusion
Case- p360a (awd-it)
Fans- coolermaster sickleflow argb (120mm) (cclcomputers)
Cooler- cougar aqua 240mm rgb (cclcomputers)
