Question Need Advice for Upgrade Current pc: ryzen 3 2200g Budget $500
Oct 15, 2019
6
Budget: $550
Mostly Gonna be used for gaming
Current
Ryzen 3 2200g
8gb ram
450w Psu
720p Monitor
Im considering to get Either
Ryzen 5 2600
rx 580
Seasonic Plus gold 550w
1080p 60hz Monitor
OR
RX 580
1080p 144hz Monitor
Which One Should I get? or are there better stuff to get thanks.
Lutfij
You should include detailed specs for your build. What type of rams are you working with? A dual channel kit rated to run at DDR4-3200MHz will help provide some more oomph to the platform, if you decide to go for the R5 2600.
You forgot to mention the make and model of your motherboard as well.
In fact you should list specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU: e.g: make and model of unit
Chassis:
OS:
Oct 15, 2019
6
im not the best with pcs so thats just the stuff i think i should Upgrade But if theres More Important Stuff I should Prioritize/ Better stuff to Upgrade Then I would I just dont know what
Oct 15, 2019
6
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
Chassis:
OS:
CPU:Ryzen 3 2200g
Motherboard:Asrock B450m HDV
Ram:Team elite 2x4gb 2666mhz
SSD/HDD:Seagate baracuda 1tb
GPU:intergrated Vega 8
Psu: MWE 450w
Chassis: DA TALITAKUM MIRROR (3 Fans) 1 on the back 2 front
OS:Windows 10
Monitor 768x1366 20inch
