need advice ga-965p-ds4 build
timber715
51
i'm new at this and not sure if i did the right thing, and i definitely need your advices and suggestions...
this is my setup:
gigabyte ga-965p-ds4 bios version: F6
intel pentium d 926 3.0mhz dual core
kingmax(Nanya technology) ddr2 pc667 512mb x 2
seagate 80gb and samsung 250gb hard disks
gigabyte g-power pro cooler (air)
So far got my timings at 3-3-3-9
memory frequency is 480MHz
Bus speed 240MHz
FSB:DRAM 1:1
multiplier is 15x
rated FSB 960MHz
core speed is 3600MHz
its pretty stable with memtest and prime95, but i don't know if this is right, first am i suppose to have a 480MHz for my pc667 RAM? is it better or need i try to change it?
increased the Ram voltage to 2.10volts and processor voltage to 1.38volts from 1.28volts
holding temperature is 50C
dont really need a high oc, just high enough not to overheat... runs 57C to 62C with prime95
timber715
51
thanks for the reply, this is my first overclock and im not really sure that what im doing is correct. will try and reply again thanks
would appreciate other recommendations...
timber715
51
hehehehe, sorry got a stupid advice that it was the better deal back then.... looking forward to e6400 soon, as soon as cash is available. huhuhu.
cheers
