Thanks for taking the time to read this thread and any help or advice would greatly be appreciated 😀
I've been having issues lately with my computer crashing. I do not get a BSOD but instead while loading into a Game my screen will freeze and then my computer will restart.
I ran "WhoCrashed" and these are the results
On Tue 1/30/2018 8:46:12 PM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\013018-5734-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1756E0)
Bugcheck code: 0xFC (0xFFFF9D89480DED48, 0x8A000002230009E3, 0xFFFF8485AFAA7960, 0x3)
Error: ATTEMPTED_EXECUTE_OF_NOEXECUTE_MEMORY
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that an attempt was made to execute non-executable memory.
crash dump file: C:\WINDOWS\MEMORY.DMP
This was probably caused by the following module: ntkrnlmp.exe (nt!memset+0x42E34)
I've used command to "sfc/scannow" and "chkdsk" and everything came back normal. I've also ran windows memory diagnostics tool which also came back normal.
Here are the specs to my PC build
Windows 10 Home 64bit (Latest updates)
Ryzen 5 1600
Zotac GTX1070 Mini
2x8GB Corsair Vengeance LPX DDR4 3000MHz
GIGABYTE GA-AB350 Gaming MB
Samsung SSD 850 evo 250 GB
WD Blue 1TB Harddrive (WD10EZEX)
EVGA 600 80+ BRONZE 600W PowerSupply
Im running latest MB bios and I've checked all hardware for latest drivers. I've checked for malware/viruses with no results.
Any help is greatly appreciated. Let me know if there's any other info needed to diagnose or pinpoint my issue.
Thank You
Ryzen 5 1600
Zotac GTX1070 Mini
Thank You
