Question Need advice: Mild overclocking on a i5 8600k.
Mar 7, 2019
Looking for cooler that will keep temps low for mild overclocking on a i5 8600k and would fit into a micro atx case. I would prefer an air cooling and didn't want to spend over $100.
CPU: Intel - Core i5-8600K 3.6 GHz 6-Core Processor ($268.00 @ SuperBiiz)
Motherboard: MSI - Z370M MORTAR Micro ATX LGA1151 Motherboard ($89.96 @ B&H)
Memory: Crucial - Ballistix Sport LT 16 GB (2 x 8 GB) DDR4-2400 Memory ($122.84 @ OutletPC)
Storage: Crucial - MX300 525 GB 2.5" Solid State Drive ($128.90 @ OutletPC)
Storage: Seagate - Barracuda 1 TB 3.5" 7200RPM Internal Hard Drive ($42.15 @ Amazon)
Video Card: Zotac - GeForce GTX 1080 8 GB AMP Extreme+ Video Card
Case: Corsair - Carbide Series 88R MicroATX Mid Tower Case ($44.99 @ Newegg)
Power Supply: Corsair - Builder 600 W 80+ Bronze Certified ATX Power Supply ($89.89 @ OutletPC)
Monitor: Acer - XG270HU 27.0" 2560x1440 144 Hz Monitor ($386.34 @ Newegg Business)
Total: $1173.07
That case doesn't allow very big coolers (up to 150mm tall.) The Scythe Fuma is one cooler that is beefy yet stands pretty short due to the 120mm fans on it. It also has a very nice price. It should fit. To my knowledge it is the best cooler under 150mm tall. Although, you could probably compare it to the be Quiet! Dark Rock TF.
https://www.newegg.com/Product/Prod...&cm_re=scythe_fuma-_-9SIA9ZH6CU1449-_-Product
