I am focusing on gaming primarily Battlefield 3, SWTOR, Skyrim at 60FPS on 1080p resolution. I also download and stream movies/t.v shows often but I do not keep them on my current laptop after viewing them. I would be interested in burning blu-ray movies and dvd's.
My max budget for this PC $1,500 roughly any ideas on where I could save money and still have peak performance I am all ears. However, if no one can find where I can save some money I guess I will be stuck paying $1,868.91. I am looking to buy in the next month or two I was debating getting the pieces of hardware over time instead of buying all at once. Then I thought what if I receive a piece of hardware and its DOA and I don't test it for months before I build my PC then I will no longer be able to return it so I am thinking I will have to wait and spend my money lump sum.
I am currently looking at hardware from newegg.com because they have such an expansive selection and easy to navigate website. I have found cheaper prices on Amazon.com for some of the hardware. I would however more than likely buy all hardware from one site.
CPU: i7 2600K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070
MOBO: ASUS P8Z68-V PRO/GEN3
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131790
GPU: Sapphire Radeon HD 7970
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102961
RAM: G.SKILL Ripjaws X Series (2x4GB) DDR3 8GB (1600)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231445
SSD: OCZ Vertex 3 120 GB SATA III
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227706
HDD: Western Digital Caviar Black 1.5TB 7200 RPM 64MB Cache
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136793
PSU: SeaSonic Platinum 860W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151111
Optical Drive: Samsung Black 12X BD-ROM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151232
Case: Corsair Special Edition White Graphite Series 600T
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139005
OS: Windows 7 Home Professional 64-bit OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
I would like to overclock and I have no experience with it or building a PC, but I am sure I can figure it out I have already been looking into it. I am not sure if I should look into downgrading GPU's and running SLI/Crossfire to achieve the same performance as the 7970 for a cheaper price if that is possible.
I have no idea if I should look into a heatsink for my CPU, I have no experience with water cooling and how complicated it is and is it worth doing, I am looking at using my 120hz 55in led 1080p t.v as a monitor for this system does anyone recommend me not doing this I was going to use the HDMI input on my tv.
Total Price: $1,868.91 USD kind of more than I wanted to spend but I think this has everything I would need other than heatsink/fans/watercooler and anything else I may have over looked.
CPU: i7 2600K
