I'm planning to build my first computer soon. I've done a lot of research and this is what I've come up with. I think I've come up with a good value build that has some good power, but I wanted to see what you guys think of it. Does this build seem balanced? Does anything stand out as not being a good fit? Any advice would be appreciated.
Just FYI, my objective has been to keep my build around $500 to $700, and to end up with a computer that has good upgrade potential and good all around ability to handle games and media.
So here's what I've come up with:
Case: Cooler Master RC-690
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137&Tpk=rc-690
Power Supply: Corsair 650tx
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005&Tpk=650tx
Motherboard: Gigabyte GA-MA790X-UD4P
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128387
CPU: Phenom II X3 710
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103648&Tpk=phenom%20II%20x3%20710
GPU: Sapphire 100259-1GL Radeon HD 4870 1GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102801
RAM: OCZ Reaper HPC 4gb
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227289
Hard Drive: Wester Digital Caviar Black 500gb
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136320
Optical Drive: Samsung Black 22XSH-S223F
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151171&Tpk=samsung%20black%20s223f
Any thoughts? Are there any obvious incompatibilities that I'm missing here? Are there any bottlenecks that I should be aware of?
Thanks in advance.
Thanks in advance.
