Hi folks.
If you were to build a PC around a Ryzen5 CPU, what parts would you select?
Yeah, I'm asking a lot, but I'm overwhelmed. In the past, I have slapped together a few variations of a Windows (7) PC, the latest with an old duo-core CPU. (ancient it is). I'm a graphic designer working mostly in layout (InDesign), Web Dev, Photoshop and some Sketchup. I'm not a gamer and Sketchup is about the limit of my 3D needs. You get the picture, I don't need superfast but a good amount of memory might be useful.
I've heard good things about the Ryzen stuff but I would certainly be willing to buy a different processor like an Intel or other AMD if the cost benefit ratio is better now and will carry me for a few years.So, at this point, I'm asking if someone could make some specific suggestions for mobo/cpu combo that will fit in a mid sized box> Ideally, I want to retrofit or copy the content of a couple older hard drives (IDE I think) and I have an old video card (ATI FireGL V3600) although I bet some mobos have better integrated graphics than this card.
I want to try and do this for less than 500 bucks. Am I asking too much? Below are the parts I'll need.
As I said, I'm overwhelmed and not to technically savvy. Knowing my parameters and my meager $500 budget, could you quickly suggest some parts or a mobo combo that you like? Feel free to add some links or make fun of me.
Thank you so much!
Greg
My Current "Ye-Olde" Rig with edited specs below
CPU-Z TXT Report
Binaries
CPU-Z version 1.77.0.x32
Processors
Number of processors 1
Number of threads 2
APICs
Processor 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Pentium D 940
Codename Presler
Specification Intel(R) Pentium(R) D CPU 3.20GHz
Package (platform ID) Socket 775 LGA (0x2)
CPUID F.6.2
Extended CPUID F.6
Core Stepping B1
Technology 65 nm
Core Speed 3199.8 MHz
Multiplier x Bus Speed 16.0 x 200.0 MHz
Rated Bus speed 800.0 MHz
Stock frequency 3200 MHz
Instructions sets MMX, SSE, SSE2, SSE3, EM64T, VT-x
L1 Data cache 2 x 16 KBytes, 8-way set associative, 64-byte line size
Trace cache 2 x 12 Kuops, 8-way set associative
L2 cache 2 x 2048 KBytes, 8-way set associative, 64-byte line size
FID/VID Control no
Clock Speed 0 3199.83 MHz (Core #0)
Clock Speed 1 3199.83 MHz (Core #1)
Chipset
Northbridge Intel P45/P43/G45/G43 rev. A3
Southbridge Intel 82801JR (ICH10R) rev. 00
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 8 GBytes
Channels Dual, (Symmetric)
Memory Frequency 333.3 MHz (3:5)
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 5
RAS# Precharge (tRP) 5
Cycle Time (tRAS) 15
Row Refresh Cycle Time (tRFC) 44
Command Rate (CR) 2T
Host Bridge 0x2E20
Graphic APIs
API ATI I/O
API ADL SDK
Display Adapters
Display adapter 0
Name ATI FireGL V3600
Board Manufacturer Advanced Micro Devices Inc. (AMD)
Codename RV630
Technology 65 nm
Memory size 256 MB
Memory bus width 128 bits
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x1002 (0x1002)
Model ID 0x958D (0x0B02)
Performance Level 0
Core clock 600.0 MHz
Memory clock 500.0 MHz
Performance Level 1
Performance Level 2
Win32_VideoController AdapterRAM = 0x10000000 (268435456)
Win32_VideoController DriverVersion = 8.632.1.2000
Win32_VideoController DriverDate = 08/17/2009
Monitor 0
Model SyncMaster (Samsung)
ID SAM0194
Serial HVEA100953
Manufacturing Date Week 1, Year 2006
Size 19.1 inches
Max Resolution 1280 x 1024 @ 60 Hz
Horizontal Freq. Range 30-81 kHz
Vertical Freq. Range 56-75 Hz
Max Pixel Clock 140 MHz
Gamma Factor 2.2
Monitor 1
Model S230HL ()
ID ACR0280
Serial LTS0R0092400
Manufacturing Date Week 8, Year 2011
Size 23.1 inches
Max Resolution 1920 x 1080 @ 60 Hz
Horizontal Freq. Range 30-80 kHz
Vertical Freq. Range 55-75 Hz
Max Pixel Clock 170 MHz
Gamma Factor 2.2
Software
Windows Version Microsoft Windows 7 (6.1) Professional 64-bit Service Pack 1 (Build 7601)
DirectX Version 11.0
Register Spaces
Register space PCI
Register space PCI #2
Register space PCI Express, base address = 0x0F8000000
Register space SMBus, base address = 0x0500
Register space LPC, base address = 0x0290
Register space LPC, base address = 0x02E
A box
Mother board that supports 2 monitors
CPU
Memory 16 gigs or better
Power supply
Anything else
Thank you so much!
Greg
CPU-Z TXT Report
Binaries
Processors
Number of threads 2
APICs
Processor 1 ID = 0
Codename Presler
CPUID F.6.2
Extended CPUID F.6
Core Stepping B1
Technology 65 nm
FID/VID Control no
Chipset
Memory Type DDR2
Host Bridge 0x2E20
Graphic APIs
API ATI I/O
API ADL SDK
Display Adapters
Display adapter 0
Codename RV630
Technology 65 nm
Memory size 256 MB
Performance Level 0
Performance Level 1
Performance Level 2
Monitor 0
ID SAM0194
Serial HVEA100953
Size 19.1 inches
Gamma Factor 2.2
Monitor 1
Model S230HL ()
ID ACR0280
Serial LTS0R0092400
Size 23.1 inches
Gamma Factor 2.2
Software
Register Spaces
Register space PCI
