Need advice on best PC build of 1500$ 2016
Mrinal_2
Commendable
Mar 8, 2016
55
I know there are existing thread with the same question but there isn't any thread of same topic in 2016, as the prices of components have been dropped and there is an option of skylake. So sorry for posting it again.
This will be my 1st pc build so i did a lot of research although still confused. Can i go for 980 ti with this budget? If yes then which 980 ti should i choose?
1. Asus Strix 980 Ti
2. EVGA Hybrid 980 Ti
3. Zotac AMP Extreme 980 Ti
I heard the above 3 gpu's are best for cooling and performance. So chose these. With 1500$ budget, I dont think i will be able to do 4k Gaming. But still getting the gpu to do 4k gaming as after few months i think i will be able to afford a 4k monitor.
I still don't have a clue which mobo i should go for. I dont know anything about mobo. So any info will be helpful.
For an overclocking rig, with SLI capability.
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor ($244.99 @ Amazon)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler ($34.50 @ Newegg)
Motherboard: MSI Z170A SLI PLUS ATX LGA1151 Motherboard ($132.98 @ Newegg)
Memory: Corsair Vengeance LPX 8GB (2 x 4GB) DDR4-2400 Memory ($48.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($86.75 @ OutletPC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($45.99 @ SuperBiiz)
Video Card: Zotac GeForce GTX 980 Ti 6GB AMP! Extreme Video Card ($649.99 @ Amazon)
Case: Phanteks Enthoo Pro ATX Full Tower Case ($99.99 @ Amazon)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply ($119.99 @ Amazon)
Optical Drive: LG GH24NSC0B DVD/CD Writer ($15.89 @ OutletPC)
Total: $1480.06
Generated by PCPartPicker 2016-03-10 10:43 EST-0500
If you are considering any kind of game recording, and video work, this would be my pick. You get i7 performance, and blck overclock ability. Also went with a larger capacity SSD, and no SLI.
CPU: Intel Xeon E3-1230 V5 3.4GHz Quad-Core Processor ($249.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 8GB (2 x 4GB) DDR4-2133 Memory ($45.99 @ Newegg)
Storage: Sandisk Ultra II 480GB 2.5" Solid State Drive ($129.00 @ Adorama)
Case: Corsair Carbide Series 300R Windowed ATX Mid Tower Case ($79.99 @ Amazon)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($99.99 @ Amazon)
Other: ASRock Fatal1ty Gaming E3V5 Performance Gaming/OC ($145.98)
Total: $1497.31
Generated by PCPartPicker 2016-03-10 10:53 EST-0500
Great picks....couldn't have asked for any better but the thing is I am from India and the components costs a way lot here. And buying from amazon.com or newegg will cost me 100$ more for every part for import fees.
