need advice on build
Conman270
46
http://pcpartpicker.com/p/8CDvqs
will this work?
will CPU cooler block ram?
any suggested changes?
is there any cheaper yet reliable alternatives?
plan on overclocking and playing allot of games on high settings.
also going to use aerocool touch 2100 fan controller is this going to work
and is it reliable.
Looks good, might change the CPU cooler to the Hyper 212 EVO, about $30-35 (and then don't have to worry about DRAM the Fan is height adjustable, can stick any DRAM under it ;) )
Dark Lord of Tech
Retired Moderator
Drop the fans for now , and get this case , its better.
Here are changes I would make.
CPU Cooler: Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing CPU Cooler ($24.97 @ OutletPC)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-2400 Memory ($84.99 @ Newegg)
Case: Enermax ECA3280A-BR ATX Mid Tower Case ($74.99 @ Amazon)
Power Supply: XFX TS 550W 80+ Bronze Certified ATX Power Supply ($25.99 @ Newegg)
Total: $210.94
http://www.newegg.com/Product/Product.aspx?Item=N82E16811124155
This is the case.
