Need advice on building my gaming PC (first build)
firstrig1992
Hello!
I am planning to build a PC capable of running games at 1080p. I did some research online and decided on the following components:
CPU: AMD 4GHz AM3+ FX4300
Motherboard: Gigabyte GA 78LMT USB3
Graphics card: Asus GeForce GTX 750Ti 2GB DDR5
PSU: Corsair VS450
Storage: Samsung 850 EVO 120 GB SSD & Seagate Barracuda 1 TB
Cabinet: Corsair Carbide SPEC 03
RAM: 2x Corsair Vengeance 4GB DDR3
Monitor: Dell S2240L 21.5 inch FHD
Kindly tell me if this is a configuration that will suit my needs and whether the parts are compatible.
popatim
Personally I wouldnt build with the 4300, start with the 6300 or better yet the 83xx series.
Even better for gaming would be a intel build for gaming.
Post your budget and I'm sure you'll get quite a few options you didnt know you had.
Similar threads
