I'm planning a new build and there are 2 things i'm hung up on .The first thing is a way to regularly back up my system drive.I've had a hard drive die on me before.I was messing around on my computer one morning and just like that, with no warning, or signs anything was failing, I get a blue screen with a bunch of text flash across my screen faster than I can read it.When I turn my computer back on it won't boot into Windows because, as I would later find out, my hard drive was dead.Since then i've had it in my head that when the time came to get a new computer I was going to have my system drive setup in RAID 1 because I want some kind of redundency in place so, that in the event this happens again, I can simply discard the failed drive and pick back where I left off like it didn't happen right down to the same wallpaper and where my desktop icons are positioned.I'm not some sort of expert on this though.I've never actually set up a RAID before, so i'm learning things I didn't know that are making this more complicated.
For example - hardware vs. software RAID.From what I read, a hardware RAID would be better, but what's a good NVMe drive RAID controller to get?On top of the added cost of having to get a second NVMe drive and a RAID controller and the complexity of setting it up, i'm reading things like updating the BIOS would destroy my RAID and erase my drives.Another backup solution I guess would be to use something like Macrium Reflect to regularly make a full drive image.What are the pros and cons of both of these methods?Are there any other options I should consider?
The second thing i'm hung up on is the OS.I would really rather have Windows 11 Pro, but I know it's come out of the gate with some problems like the one it had Ryzen CPUs.I know i'm going to have this new computer for more than the few years of support that Windows 10 has left, and frankly don't want to be bothered having to upgrade later.I guess what i'm asking is how long do you think it'll take them to iron out the problems that have come up with Windows 11 atleast to the point where it would be reccomended?Not only is my computer really old, but with these supply issues and the cost of things going up, i'm feeling a bit of a sense of urgency.I feel like if I don't get a new computer now it's going to be even harder and more expensive.
