Need advice on first build.
vtphs
108
LITE-ON DVD Burner - Bulk Black SATA Model iHAS124-04 -$19.99
COOLER MASTER Elite RC-310-OWR460 Black SECC ATX Mid Tower Computer Case RS-460-PSAR-J3 Elite 460W Power Supply- $69.99
Seagate Barracuda ST31000524AS 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive Item - $59.99
ASUS M5A97 AM3 AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS $99.99
Recertified: PNY RVCGGTX4601XXB GeForce GTX 460 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support - $109.99 G.SKILL
Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL -$64.99
AMD Phenom II X6 1090T Black Edition Thuban 3.2GHz Socket AM3 125W Six-Core Desktop Processor HDT90ZFBGRBOX -$165
$604 Total - shipped
Is this a good build or should some components be swapped or added?
sonicfantom
15
That PSU will NOT be sufficient. Get a quality 500w unit from a good brand, such as Seasonic, Antec, or Corsair. I'd also look into a case with better airflow, a single 120mm fan is going to have a hard time pushing out the hot air from your GTX460.
An affordable CPU cooler would be good as well (unless you're overclocking, win which case it's a must) - something like the Arctic Cooling Freezer 7 Pro should be easy to fit into your budget, and it'll run far cooler and quieter than the boxed heatsink.
vtphs
108
This will be a daily use cpu so would a quad or six core be better? Im not extremely worried about losing 5 fps because my monitor is only 19 inch and is 1440-900 max. Overall what cpu would you recommend?
vtphs
108
The main reason i picked that case was because i liked the styling and the psu because it had my required 450w, but as you said it may not have the required cooling. I don't plan on overclocking really so would this be sufficient or not?
vtphs
108
i do tend to run quite a bit of applications, and wouldn't the new turbocore feature provide about the same clockspeed as a x4 without overclocking?
vtphs
108
Thanks =0 . Any recommendations for a different psu?
vtphs
108
Their 600watt has a promo code to be $60 too. Now i just need a case. Also i read earlier that a samsung hd wont work with the mb i picked. Do you know if thats true?
vtphs
108
I know this is tough but im looking to spend more around $40 to meet budget. Besides im not to big on glowing fans because it will be right in front of my bed. Problem is glowing fans usually mean good case+ good airflow.
Would my original case be that bad that i should forget about it?
http://www.amazon.com/Cooler-Master-Elite-Tower-RC-310-BWN1-GP/dp/B0028ACYMC/ref=cm_cmu_pg_t
vtphs
108
That case is a little more my style. Heres the post about the hardrive : If you have a Spinpoint F3 1TB drive, you may need a firmware update as the SB950 southbridge used on this is functionally identical to the SB850 which has compatibility issues with that hard drive. Make sure you've got it plugged into SATA1, make a USB boot disk, switch the SATA controller to IDE mode, get the firmware update at Samsung's website, and flash it or it won't recognize your drive (it's a non-destructive update).
What do you think i should do?
vtphs
108
Would this psu be sufficient because i can get it in a combo with ram for $85, then i can get the antec case you recommended.
