This is an update on the external USB 3 Seagate Backup Plus 2TB drive that I posted about three to four months ago but can not find the post to. That drive is now able to be read on a good day and data pulled off one file at a time. After having the drive examined it has been determined that the MBR and Backup MBR of the drive are corrupted in some manner and not showing the same data. Windows attempted an auto recovery and repair to the file system. Something that it had not done before in time window of the first post here. The 2TB drive had about 20GB of free space. In the space of two weeks pulling files one at a time when the drive can be seen by the OS I have managed to recover manually 6GB of data. However none of this data is the needed data. I have noticed that when I attempt to even look in the area of the drive that contains the needed data the drive just shuts down. Windows wont see drive until it is unplugged both USB and power wise for 30-60 seconds. Then its back to playing the old game of hit and miss described in the first post with the out come being the all too familiar "Drive needs to be formatted before Windows can use it". At one point I just gave up and told it to just go ahead and format the drive to which I got the response "This is not a Windows compatible Device"
I have pasted the first post below so people can read it. I have gotten to the point of just about throwing this drive into the incinerator as it's not even worthy of being a doorstop at this point.
J.L.Allen
1st post
External USB 3 Drive not working after a move.
I have an external USB 3 Seagate Backup Plus 2TB that worked fine up till about two weeks prior to moving across four states. During this two week period the drive would drop off of and return to the My Computer screen at random.
Was too busy preparing for the move and didn't have time to deal with the issue then so I simply shut the drive down and removed it from the system. Nothing on it was needed at the time.
After the move it was about two months before I was even able to set the system up and boot it up for a check. The computer is fine after the move and the other External a USB3 Seagate GoFlex 2TB powered up with no issues.
The Backup Plus is hit and miss.
One outta ten boots of main system and it might show up in My Computer. When it did show up it was like Russian roulette with the files being accessible or not. I use 'accessible' lightly as the file folders and directories can be gone through but any files in the folders if clicked on caused complete system hangup until reboot.
There are also times when instead of allowing access to file folders it just says the drive needs to be formatted or that it is not a usable Windows device.
Contacted Seagate on the matter and their advice was to transfer the Hard Drive from the unit into another external enclosure as the problem to them was the USB controller that serves as the base for the enclosure might of gone bad. This did not solve the issue.
My next step was to mount the drive internally and plug it directly into the Mother board as a slave drive. Computer sees it in Bios and in recovery software but Windows will not see it. Also slows system to a crawl when the drive is plugged in this way. When drive is in the enclosure system runs at normal speed even when it can 'see' the drive.
There have been no attempts to write data to this drive. I have only viewed the file structure when I can and tried to recover the files over to another drive with multiple forms of recovery software. All have failed stating that the drive is ether:
A: Not formatted.
B: Data is corrupted.
C: Data is physically not there at specified addresses given.
D: Drive is not a Windows compatible device.
This drive contains some critical work files and needs to be recovered.
System specs are as follows.
Mother Board
MSI 785GM-E51
Processor
QuadCore AMD Phenom II X4 945 3GHz
Memory
8 GB (4 x Kingston 2GB DDR3 1333 )
Video
Nvidia GeForce GTX 650 with 2 GB DDR5
Main Hard Drive Internal
SeaGate 1TB (ST31000528AS)
Second Hard Drive Internal
SeaGate 4TB (ST4000DM000-1F2168)
Third Hard Drive External
SeaGate 2TB GoFlex
Forth Hard Drive External
SeaGate 2TB Backup Plus
OS
Windows 7 Professional 64Bit with Service pack 1
DirectX
11
If you know how to fix this Thank you in advance for any info you give. The people at SeaGate Thought the USB controller board in base of enclosure had failed or the MBR for drive was corrupt in some way.
The drive does not make any of the Classic failing drive noises This drive has not been dropped or had any liquid of any kind on it. If anything I expected the GoFlex drive to fail as it has been dropped / knocked to the floor many times over the last year by a cat. Cat even knocked it off a shelf into a fish tank. Drive still runs strong with no issues.
Thank you for your time,
J.L.Allen
J.L.Allen
1st post
A: Not formatted.
Mother Board
MSI 785GM-E51
Processor
Memory
Video
SeaGate 2TB GoFlex
OS
DirectX
11
J.L.Allen
