Need Advice on i5 2500k/GTX560 build
buoyah
6
Approximate Purchase Date: Ordering the parts this week.
Budget Range: $800 before rebates, but would prefer to spend about 700 ish
System Usage from Most to Least Important: Gaming
Parts Not Required: Monitor, Mouse, Keyboard
Preferred Website(s) for Parts: Newegg
Country of Origin: USA
Parts Preferences: Intel, Nvidia
Overclocking:
In the future YES
SLI or Crossfire: In the future YES
Monitor Resolution: 1920x1080
Additional Comments: Need a well rounded gaming PC that can play all current games.
Need a build that supports I5 2500K and GTX 460 Fermi 1gb.
I found this set up in New egg for $685, would love to get feedback or upgrades on any parts that would make the computer running better.
http://www.newegg.com/Product/ComboBundleDetails.aspx?ItemList=Combo.692056
1x Rosewill FUTURE Gaming ATX Mid Tower Computer Case,come with Four Fans-2x Front Blue LED 120mm Fan,1x Top 120mm Fan,1x Rear 120mm Fan,Support up to 7 Fans (Model:FUTURE)
$69.99
1x ASUS P8P67-M (REV 3.0) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard (Model:p8P67-M (REV 3.0))
$129.99
1x ASUS ENGTX560 DCII OC/2DI/1GD5 GeForce GTX 560 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card (Model:ENGTX560 DCII OC/2DI)
$199.99
1x Antec BP550 Plus 550W Continuous Power ATX12V V2.2 80 PLUS Certified Modular Active PFC Power Supply (Model:BP550 Plus)
$64.99
1x Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K (Model:BX80623I52500K)
$219.99
1x Kingston HyperX X2 Grey Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 Desktop Memory Model KHX1600C9D3X2K2/4GX (Model:KHX1600C9D3X2K2/4GX)
$44.99
1x Seagate Barracuda ST3500413AS 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive (Model:ST3500413AS)
$39.99
nd_hunter
675
You can do better for $800. That combo is missing an optical drive, so add $20 for that. The RAM is 1.65V, which is more than whats recommended for Sandy Bridge, plus it's pretty expensive for a 4GB kit (combo savings aside). That motherboard does SLI at x16/x4 which is not ideal. You can get cheaper cases.....
CPU: Intel Core i5-2500k
Motherboard: MSI P67A-G45 (SLI ready at x8/x8)
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.660241
$332.98 ($20 MIR available)
RAM: 4GB G.Skill 1600Mhz C9 1.5V (low profile, cheap, correct voltage for Sandy Bridge)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231193
$32.99
GPU: EVGA GTX 560 Ti (more powerful than the GTX 560)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130604
$239.99 ($25 MIR available)
HDD: 500GB Seagate Barracuda
Optical: Samsung 22x DVD Burner
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.696167
$53.48
PSU: XFX Core Edition PRO650W (Enough power and connections for future SLI)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817207014
$89.99 ($10 MIR available)
Case: Rosewill Challenger
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
$49.99
Total: $799.42 + $14.75 standard shipping
Don't forget, there's $55 in available rebates...
If that's too much, you can drop the vid card to a GTX 560 (non-Ti) or even an HD 6870.
nd_hunter
675
Really?
http://www.hardocp.com/article/2011/02/21/msi_n560gtx_ti_twin_frozr_ii_oc_sli_review/9 <--OC'd SLI 560 Tis (965/1930/1090), OC'd i7-920 @ 3.6GHz, 628 watts peak while gaming. Subtract roughly 50 watts for an overclocked i5-2500k and you're looking at around 580 watts. Figure in 80+ Bronze (85% at best) PSU efficiency, and the PSU is outputting approximately 493 watts, well under it's rated 650 watt output.
madchemist83
i am pretty sure you suppose to take 85% from your PSU power as a 0.85*650=552 and not from the power your system is demanding. Also PSU will usually go higher under load. Just to be safe I would go for either really good 650W or 700W. Unless u sliing cfing something lower then 560ti. Anandetch reports ASUS 560ti under heavy load 310W so ther goes your PSU. Also yopu don't want to be on the edge
madchemist83
This build is nice though
i'd drop case for HAF 912
ram 1300 is enough
and get sammy f3 for a little extra
also msi mobos have high fail rate so look into asrock or asus
and lastly you'll need CPU cooler like hyper 212+ or scythe something something (sorry forgot) and that's extra 30
Just like I said it's hard to fit i-5 2500k and 560ti into 800 budget especially for someone looking to spend preferably 700 don't forget taxes and shipping that will put u in 850+ also I'd rather pick parts that have no MIR as they r pain in the @rse.
So with all that said I think we can work some recomendations for u pretty quick :)
nd_hunter
675
Rated output is rated output...that alone has nothing to do with 80+. At 85% efficiency, it means that to output 650 watts to the computer it must take in 747.5 watts from the wall. The rest is lost to heat. That XFX PSU I linked puts out 624 watts on the 12V rail alone (watts=volts*amps). Click the link below for more info.
http://en.wikipedia.org/wiki/80_plus
Plus I didn't suggest an ASUS card, I linked to an EVGA reference card and Anandtech has a system with an overclocked i7-920 and a reference 560 Ti pulling 352 watts loaded under Furmark, 317 watts during Crysis. As we know, Sandy Bridge takes less power than Nehalem.
http://www.anandtech.com/bench/Product/330
You are correct in that you don't want to be on the edge, but I don't think that 150+ watts of headroom is on the edge.
nd_hunter
675
For the record, I did fit a 2500k and 560 Ti into an $800 budget, shipping and tax not included, however if he lives in a state without a Newegg distribution center, there is no tax. Rebates were not figured into the $799 total and had no bearing on the parts that I picked...they are simply a bonus if you get them back.
madchemist83
^ Thanks for clearing this out for me. I am actually looking at getting that combo into 800. And I have microcenter close by(kinda). So you saying I can get system with i-5 2500k 560ti and mobo for future sliing for 800? interesting.
My reference shows the overclocked SLI GTX 560ti s pulling, at peak, 400W.
http://forums.atomicmpc.com.au/index.php?showtopic=264
Those are all calculated figures, draw from the PSU not the wall.
The rest of the system, with moderate OC, will stay under 200W. Having said all that I still would want my PSU operating in the 60-70% range when gaming.
My guess for gaming draw matches yours.... somewhere between 450 and 500W, mostly. 70% of 650 is 455. But an 80% draw is still pretty safe, just not ideal.
To toss out another number though, 90% of the people who buy one card intending to add a second later.... never do. It's the speed at which GPUs progress that makes this impractical. :)
vtphs
108
I'm doing a very similar build to you and i managed to get my price down to $750. Here's my components.
COOLER MASTER HAF 912 - $55 - http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
SAPPHIRE 100314-3L Radeon HD 6870 - $175 - http://www.newegg.com/Product/Product.aspx?Item=N82E16814102948
Antec EarthWatts EA-650 - $55 - http://www.newegg.com/Product/Product.aspx?Item=N82E16817371044
GSKILL Ripjaws X Series 4GB (2 x 2GB) - $32 - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231438
COOLER MASTER Hyper 212 Plus - $28 - http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Seagate Barracuda + Lg Cd/Dvd combo - $68 - http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.696151
I5 2500k + Msi P68 - $324 - http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.660241
BYTECC 6 ft. 18AWG Power Cord - $5 - http://www.newegg.com/Product/Product.aspx?Item=N82E16812270406
Exactly $750 Shipped
Hopefully it will help you drop the price a little and get more for your money.
vtphs
108
I Dont do Mail In rebates.
madchemist83
^ whatever .. that's what I said 2 weeks ago. You should just go for best performance for your money // and if u can't spend extra 50 bucks on a rig // then just spend 700 or 650/ what's the point? right
