So i was planning on making a new computer with each component having integrated RGB. I have never installed RGB components before as my current computer doesn't have any sort of RGB lighting on it. I wrote this post as i couldn't find any guide on RGB installation. This is the build that i would be building https://pcpartpicker.com/list/qPP7MZ as i am trying to sync everything to asus aura sync.
So from what i understand, some components such as the RGB ssd or RGB fans requires a usb port to light up the RGB? And as the motherboard has limited usb headers, i have to get an internal usb splitter or something to cater to all the usb ports that the RGB in the build needs? And there's also the RGB header in the motherboard that also connects to the RGB in the components? I'm quite confused.
So is the usb headers and the RGB headers the same? And that i can connect to any one of it to make the RGB light up? And if it is, based on the build given above, how many usb/rgb expansions do i need to buy to ensure i would have enough slots in my build to light up all the RGB's? And could ya'll introduce me to some expansions that i can get?
And last question, as im getting the coolermaster masterliquid cpu cooler which has 2 fans and an additional 3 fans to put one at the back and 2 at the front of the case, do i need to get some kind of fan controller to cater to the 5 fans in my build as im sure the motherboard do not have 5 fan slots?
Thanks a lot in advance for helping guys! Any advice is much appreciated
