Hi everyone. I could really use some advice. I would like to build a SFF PC between now and Christmas. The sooner I figure out the parts, the sooner I can build it.
Budget Range: Between $1000 and $1500 USD.
System Usage: I would primarily use this as a gaming rig with htpc functionality on the side. I already have the xb360 wireless controller with PC dongle and will be reusing that.
Are you buying a monitor: No, I already have a 1080p monitor and a 1080p LED HDTV.
Parts list: http://pcpartpicker.com/user/omni461/saved/#savedbuild_1682017
Still undecided on a cooling solution. I chose the hadron hydro over the Air, to save myself a bit of money down the road, should I ever decide to use liquid cooling. I don't plan on overclocking so liquid cooling may not be worth the extra expense. Plus I hope to use this like a LAN box; moving it around quite a bit. Your advice here would be greatly appreciated.
Do you need to buy OS: Yes. Windows 7
SLI or Crossfire: Nope. Not worth the expense at 1080p.
Additional Comments: I would like a semi quiet PC. I plan on running BF4, Shadow of Mordor, the Witcher 3, GTA V and various other upcoming games. I would also like the option to use it as a media center for watching blurays, netflix, and live streams via xbmc. The case may be too small to fit any DVR hardware, so I skipped it. Basically I need someone to double check the parts I selected, in case I goofed somewhere.
Thanks!
Thanks!
