Need advice on Mobos and overclocking for my build
cansanityriver
Commendable
Aug 18, 2016
Approximate Purchase Date: Within the next month
Budget Range: 1300-1600
System Usage from Most to Least Important: Pretty frequent gaming and movies
Parts Not Required: Mouse, Speakers, Keyboard
Preferred Website(s) for Parts: Newegg and Jet
Country: United States
Parts Preferences: I like Asus but I'm open to most brands
Overclocking: Undecided
UPDATE: I think I would like to overclock at some point. From what I'm reading I would need an MSI Mobo to overclock the i7 6700 processor. Should I return it for the 6700k?
SLI or Crossfire: Maybe but I probably won't need it.
Monitor Resolution: 4k
Additional Comments: I want to be able to run 4k smoothly, without having to worry about upgrading for a few years at least. I got pretty good deals on the parts that I've already purchased. I didn't plan on overclocking but I'm considering it more and more as I get closer to build day. That being said, I know that I can't overclock with the i7 6700. At the time of this posting I could still return it if need be. I'm up in the air at this point so any advice or tips would be appreciated. Other than that I need help picking a motherboard, a case, and do I have a big enough power supply unit?
Already purchased:
GIGABYTE GeForce GTX 1070 DirectX 12 GV-N1070G1 GAMING-8GD 8GB 256-Bit GDDR5 PCI Express 3.0 x16 ATX Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125871
Intel Core i7-6700 8M Skylake Quad-Core 3.4 GHz LGA 1151 65W BX80662I76700 Desktop Processor Intel HD Graphics 530
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117560
EVGA 500 B1 100-B1-0500-KR 80+ BRONZE 500W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817438012&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
UPDATE: EVGA 750 GQ, 80+ GOLD 750W, Semi Modular, Power Supply 210-GQ-0750-V1
https://www.amazon.com/EVGA-Modular-Warranty-Supply-210-GQ-0750-V1/dp/B017HA3RGE/ref=sr_1_2?tag=slickdeals&ascsubtag=7839b86e655711e6a7bdee931686208f0INT&ie=UTF8&qid=1471531948&sr=8-2&keywords=Evga+gq
GeIL EVO POTENZA 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3000 (PC4 24000) Desktop Memory Model GPR416GB3000C15ADC
http://www.newegg.com/Product/Product.aspx?Item=N82E16820144929&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
UpStar M280A1 High Glossy Black + Hairline 28" 4K UHD HDMI Display Port Widescreen Backlight LCD Monitor
http://www.newegg.com/Product/Product.aspx?Item=N82E16824511002
Hmm, before doing anything else, I would change that power supply. It's not very good.
Also you said you bought a 6700, if you want to overclock you want a 6700K
Try to RMA your i7 6700, if you can't do it, then try with a motherboard that can overclock non-k cpus like Asrock, Msi or EVGA,
About your power supply you rather change that one , it just hits the limit line and would make force it to work always at max levels, try something between 650w and 850.
In any case you change your i7 6700 to a K-Type then check this one:
GIGABYTE GA Z170X UD5 http://www.newegg.com/Product/Product.aspx?Item=N82E16813128838&cm_re=z170-_-13-128-838-_-Product
If you want to stick to Asus then
ASUS Z170-E http://www.newegg.com/Product/Product.aspx?Item=N82E16813132691&cm_re=asus_z170-_-13-132-691-_-Product
Hey thanks for the response! I bought the power supply when I thought I was going to do a budget build but now that is not the case. I'll probably return it since multiple people have suggested a better one.
Is RMA hard to figure out? I didn't know that there were motherboards that would allow me to overclock a non-k processor. Thanks for the response!
