Need advice on mounting locations for two 120mm radiators
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
I'm sure lots of you have more experience than I do with building pc's that have two liquid cooling radiators, so I'd like some advice. I'm getting the case pictured below and I have two 120mm radiators I have to mount (one for CPU, one for GPU). The positions labeled A,B,C, and D are all open and available to mount, the two that don't get the radiators will get fans instead. The case comes with a 200mm fan on front and 140mm on the rear. What two points would you suggest mounting the rads on?
Ok, thx.
I think the best option is to put the cpu rad on the top 120mm fan mount, then put then GPU rad on the bottom fan mount. Since GPUs take less cooling power, putting the rad on the bottom should be good enough.
would having both rads up top possibly get too hot? I'm worried there may not be enough airflow beneath the case if I put the gpu rad on the bottom, it is a single 120mm for dual gpu after all
