Need advice on my build, any thoughts?
TechieEditingFr3ak
16
Hey guys i am from India and here's my new build that i will use for probably a year then i will get a new more overkill one any thoughts on this build i am kind of new to hardware so here it is
Main use Hardcore video editing and after effects with gaming BF4,Crysis 3,Rivals,Run,ASC IV Black Flag,Far cry 3
CPU i7 4770k 24000/-
CPU Cooler Cooler Master Hyper 212 EVO Cooler 3150/-
Mobo Gigabyte GA Z87x UD3H 15600/-
Ram Corsair vengeance 8gb 8x1 (plan on upgrading later) 6000/-
HDD WD Cavier Blue 1 TB 4200/-
GPU MSI Twinforzer gtx 770 2gb 21000/-
PSU Corsair Vs 650W 4010/-
Case Corsair Carbide 200R Compact ATX Case 4500/-
I will add a SSD later and i will dual boot this with OS X Mavericks and Windows 8.1
Are all of these compatible with the case?Is the PSU Good these are my only concern.
Thanks to everyone!
Everything is compatible, although:
-I can see you have pretty expensive parts, why not investing in better PSU. Corsair's VS units are similar to CX units and they are considered budget series. Get something above CX or VS, like TX and above, or something else from the brands such as: Antec, XFX or SeaSonic in the range of 600-650w
-Corsair's 200R is good case and it will fit all the parts you have listed, but maybe it is better to get bigger case, and not worry in the future about buying new case.
Thanks for the reply bro😀, can you suggest one PSU under like 7000rs from flipkart which have good reviews and that is a trusty one i don't want something to go wrong with my first build.
As for the case i will get a Fractal Design R4 Within a month from amazon so this case is for temporary purpose.
BTW Thanks
