Need advice on my first budget gaming build
Metalurch
7
Hey guys,
I am going to be making my first ever budget gaming build
8GB (2x4GB) Corsair DDR3 Vengeance Jet Black, PC3-12800 (1600), Non-ECC, CAS 9-9-9-24, XMP, 1.50V
1TB Seagate ST1000LM014 2.5" Solid State Hybrid Drive, SATA III Slim 6Gbs 8GB SSD 64MB Cache PC/MAC/PS4
Asus H81M-PLUS, Intel H81, S 1150, DDR3, SATA III - 6Gb/s, PCIe 2.0 (x16), D-Sub/DVI-D/HDMI, Micro ATX
2GB EVGA GTX 750Ti SC GAMING Mini ITX, PCIe 3.0, 5400MHz GDDR5, GPU 1176MHz, Boost 1255MHz, Cores 640, DP/HDMI/DVI-I
Intel Pentium K G3258, LGA 1150, Haswell, Dual Core, 3.2GHz Clock, 1100MHz GPU, 32x Ratio, CPU, Retail
CiT Marvel Rubber Coated Case with USB 3.0, Side Window & 2 LED Fans
Corsair VS550 550W Power Supply
CP-9020097-UK - 550W Corsair VS Series VS550, 85% Eff, 80PLUS White 230v EU Certified, 1x120mm Fan, Black Casing+Sleeved Cables, ATX PSU
Please note i already have an OS that i can install, my budget it £350, i need to know if this is fully compatible and really worth the money i will be spending, any advice would be greatly appreciated.
Thank you
should work ok, though the pentium dual core may struggle in some games that really want 4+ threads (GTA V, Fallout 4, Battlefield 3 & 4 come to mind)
this desn't have as powerful a cpu, but the gpu is better, should get 50+ FPS on high in most games, some can run ultra:
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor (£58.83 @ Amazon UK)
Motherboard: Gigabyte GA-F2A88XM-DS2 Micro ATX FM2+ Motherboard (£41.99 @ Amazon UK)
Memory: Kingston HyperX Fury White 8GB (2 x 4GB) DDR3-1866 Memory (£32.98 @ Amazon UK)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (£37.14 @ Aria PC)
Video...
Video Card: Zotac GeForce GTX 950 2GB Video Card (£121.98 @ Ebuyer)
Case: Rosewill SRM-01 MicroATX Mini Tower Case (£23.99 @ Amazon UK)
Power Supply: Antec EarthWatts Green 380W 80+ Bronze Certified ATX Power Supply (£38.26 @ Amazon UK)
Total: £355.17
Generated by PCPartPicker 2016-01-29 00:08 GMT+0000
Hello, thanks for the sharp reply, i will mainly be playing DayZ Standalone and world of warcraft, how does the CPU effect the games? is it loading times or gameplay in general? i do like the look of the build you posted, thank you
