Need Advice on PC Build Compatibility Check (1st)
Sam_T_
17
Hello,
I would need an advice on the following PC build:
CPU: Intel i7-3930K
GPU: MSI GTX 780
RAM: corsair vegance 16gb (2x8)
MOBO: Asus Z87 PRO LGA
PSU:Corsair CX series 750 Watt
I'd also like to know if these parts fit into the Cooler Master HAF X case...
Thank you
RCguitarist
1,763
252
I agree. Also, if you are going to be spending GTX780 level money, why not get an i7 4770k cpu? It would work great with that motherboard.
Sam_T_
17
What about the Intel i7-4930K? It should perform better.
Depends on what you're doing with the PC. If you're not doing heavy editing and/or rendering all the time, the 4770k is more than enough.
The 4930k still needs an LGA 2011 motherboard though.
Similar threads
